In current version of MW 7.12 - when I check mark all for deletion it shows the icon at the bottom of the window properly but does not put a check mark in the delete column. This is new behavior.
Thank you
Mark all for delete not adding check marks
Re: Mark all for delete not adding check marks
Which version of MailWasher do you have installed ? If it's 7.12.17 then uninstall >> keep your data files >>install .16
http://cdn.firetrust.com/downloads/mail ... _12_16.exe
- Digerati
- Microsoft MVP
Bill (AFE7Ret)
Freedom is NOT Free!
FTR - mark for all works fine for me (7.12.16).
- Jelting2
My problem is in this same area. However, MW is marking eails to delete and they are being deleted. My problem is that the good emails are not coming down to my Outlook inbox. It was working great until I updated to ver. 7.6.12.
What is my fix?
Correction: my version is 7.12.6
What is my fix?
MailWasher cannot stop emails loading into Outlook, are you saying Outlook cannot load any new emails at all ?
- AjTeX
MW Pro 7.12.17 ... A lot of issues !!??
There are a few bugs in this version. I am experiencing mails marked for Deletion or SPAM or Blacklist... and they don't get deleted?
Then when selecting mails for deletion, they are not being selected by clicking on the tick-box ?
Emails that are marked safe etc. does not come through into my Mail client i.e. Outlook ?
I have reverted back to Pro 7.12.16 and everything works just perfect the way I want it to work!
Yeah it wasn't released to public, happens with betas, sometimes they don't fly right.AjTeX wrote: ↑Sat Feb 15, 2020 1:07 amMW Pro 7.12.17 ... A lot of issues !!??
