14.4.0 crashes
dsicon
14.4.0 crashes
Sat Nov 14, 2020 3:23 pm
Since today's (maybe yesterday's) update to 14.4.0 Hideaway is crashing frequently.
The crash is "Hideaway has stopped working" and then Windows kills it.
Re: 14.4.0 crashes
Sat Nov 14, 2020 9:38 pm
Hi there, we've found an issue with this latest version which affects a few people (5 now).
Download and install this version.
Make sure the old HideAway is not running (right click in the system tray), then run the installer for this new version. Seems it fixes it for people who had this issue.
dsicon
Re: 14.4.0 crashes
Sun Nov 15, 2020 9:15 am
It auto updated to 4.14.1 today should I still do this update you offered?
Re: 14.4.0 crashes
Sun Nov 15, 2020 3:39 pm
No, the auto-update is the same version so just ignore this one.
king
Re: 14.4.0 crashes
Mon Nov 16, 2020 4:15 am
Hi, In my PC after 14.4.0 update I just see white splash screen only. Even this new 14.4.1 update doing the same thing. Please help me. Thanks!
Re: 14.4.0 crashes
Mon Nov 16, 2020 8:38 am
Ok...we've had one other person with this issue. Does it still happen after you restart your PC?
king
Re: 14.4.0 crashes
Mon Nov 16, 2020 7:50 pm
Yeah. Same white splash screen.
dpillar3
Re: 14.4.0 crashes
Mon Nov 16, 2020 9:21 pm
Yes it crashes for me as well, tried uninstalling & reinstalling, still not working.
Re: 14.4.0 crashes
Mon Nov 16, 2020 10:07 pm
Could you please send us the logs. [Edited it here incase you saw the previous one]
Go to Start, type RUN, click enter and then type
%APPDATA%\HideAway
and send/pm me the log.log file. Thanks!
Re: 14.4.0 crashes
Tue Nov 17, 2020 7:30 pm
Please down and install this version and it should fix this issue.
Sorry about it, seems it only happened to a few people but is from an update to the user interface code.
king
Re: 14.4.0 crashes
Wed Nov 18, 2020 7:59 am
***This new update worked like charm.. Fixed my white splash screen issue and working perfectly. Thank you for the quick support. :bow
Re: 14.4.0 crashes
Wed Nov 18, 2020 8:30 am
Excellent, thanks for letting me know.
sparkyspark
Re: 14.4.0 crashes
Sun Nov 22, 2020 10:15 pm
Latest automatic update when opening HideAway is showing as v4.14.1 yet the changelog shows latest version being v4.14.2, is the programme running the latest version, or is it the latest version with a bug showing v4.14.1. Thanks
Re: 14.4.0 crashes
Mon Nov 23, 2020 10:16 am
They're both relevant, the only change is that 4.14.2 fixes the error that a few users had with a white screen showing when they started HideAway. We didn't bother auto-updating everyone as we seem to have fixed it for the people concerned.
