Empty fields after Update today?
Bigman
Wed Feb 17, 2021 3:44 am
Hello,
Mailwasher did install a new version today, and after that most information in the main screen
is empty.
Can you help me with this problem?
Actually installed is version 7.12.53.
Thank you
Kind regards from Germany
Markus
Solidbond
Re: Empty fields after Update today?
Wed Feb 17, 2021 7:39 am
Yeah - got the same problem here. Different email servers, and different blank fields out of the From, Subject and To Either all 3 are blank or just one of them, but some emails have no blank fields
oz9fb
Wed Feb 17, 2021 7:46 am
Same here, waiting a fix. for 7.12.53
Uninstalled 7.12.53 and installed 7.12.38
Solidbond
Wed Feb 17, 2021 8:22 am
Just had the following reply from support, tried it and it's worked - that's pretty good support!
Hi there,
Yes, sorry about that, can you please try setting the Spam Throttle
under Settings >> General >> Checking Mail >> to 500 lines >> Save >>
restart MailWasher.
That should resolve the issue.
Jeremy Clark :. Firetrust Support
DaveOzric
Thu Feb 18, 2021 4:51 am
That fixed it! Thanks
Anysia
Thu Feb 18, 2021 11:57 am
Installed the update and now I have even more blanks than I did before.
Sorry about that, working on a fix now. The interim solution is go Settings >> General >> Checking Mail >> set the Spam Throttle to at least 350 lines per email >> Save >> then restart MailWasher.
Thu Feb 18, 2021 3:36 pm
Here's a link to the beta fix version, it will install fine over the top. Keen to hear of any problems with blank fields
http://cdn.firetrust.com/downloads/mail ... _12_54.exe
