Hello
I want to report the following crash during the action of selecting and washing mails a few times after one another
12/06/2021 21:20:51 ERROR: API is null - Message not logged=MailWasher Closed
13/06/2021 11:20:30 Message: Value was either too large or too small
13/06/2021 11:20:30 Stacktrace: bij System.Convert.ToChar(Int32 value)
bij MailWasherPro.MailPreview.ParseHTMLEscapeCharacters(String str)
bij MailWasherPro.MailPreview.GetPlainTextParagraph(EmailTableRow row)
bij MailWasherPro.MailPreview.PopulatePlainTextTab(EmailTableRow row, Boolean preserveScroll)
bij MailWasherPro.MailPreview.RefreshContent(Boolean preserveScroll)
bij MailWasherPro.MailGridAndPreview.set_CanLoadPreview(Boolean value)
bij MailWasherPro.MWPMainWindow.WashMailIconThreadUpdateUI()
bij MailWasherPro.MWPMainWindow.<WashMailIconThread>b__e1()
bij System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
bij System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
bij System.Windows.Threading.DispatcherOperation.InvokeImpl()
bij System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
bij System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
bij MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
bij System.Windows.Threading.DispatcherOperation.Invoke()
bij System.Windows.Threading.Dispatcher.ProcessQueue()
bij System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
bij MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
bij MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
bij System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
bij MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
bij MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
bij System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
bij System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
bij System.Windows.Application.RunDispatcher(Object ignore)
bij System.Windows.Application.RunInternal(Window window)
bij System.Windows.Application.Run(Window window)
bij MailWasherPro.Startup.Main(String[] args)
13/06/2021 11:20:32 Stacktrace: bij MailWasherPro.Startup.Main(String[] args)
Crash on 7.12.54
Re: Crash on 7.12.54
That's a new one I think, can you first try running a .NET Repair, takes around 10 minutes.
Let me know if crash continues after that.
- BlackBird74_
I now have one entry that shows red when I select it.
This items cannot be washed.
Why might that be?
Why might that be?
- Mailwasher red.png (14.22 KiB) Viewed 2467 times
Try removing the account from MailWasher >> restart the program >> add the account back in, that will hopefully clear the rogue email.
