Server down?
daven
Server down?
Tue Oct 05, 2021 4:59 am
This morning, I was faced with being asked to login to the app. Neither login nor password reset works - "Unable to contact server".
Is it down?
Thanks,
Dave
daven
Re: Server down?
Tue Oct 05, 2021 5:48 am
Operational again. Thanks :)
Re: Server down?
Fri Jun 21, 2024 8:06 am
Great, thanks for letting us know!
Daphne Brown
Re: Server down?
Thu Sep 12, 2024 7:52 pm
Looks like the app server is having problems, me too.
Re: Server down?
Fri Sep 13, 2024 8:16 am
Yes, seems to be working now when I check, however my account that was in it as vanished, so looks like it had some sort of issue alright...
If you have also lost account/s just re-sync them as below....
First, log off MW Mobile, (icon for this top L/H side in MW Mobile >> Logout)
then in MWpro click, Settings>>Sync>>Logout,
then log back in again and click "Mobile", and tick the accounts/lists you want to sync, then click Sync.
Open Mailwasher on your mobile, click "Log in", enter your email address and password, and you should be all set.....?
