MW settings for Protonmail account
- panhead
I am having problems with the settings of the Protonmail account I am trying to add. I get the 'Failed to login to server for your account' message. Anyone knows what the setting should be?
Re: MW settings for Protonmail account
ProtonMail doesn't look to support IMAP or POP access unless you are using their ProtonBridge App, https://protonmail.com/bridge/
However this isn't available for free users.
If that is installed, it should be
Username : Your full email address
Server Address : 127.0.0.1
Port : 1143
SSL enabled
Port : 1143
SSL enabled
- panhead
OK, under Help >> User Files >> open the Logs folder >> open the folder named after todays date >> there will be a file called MWPapp_xxx.log where xxx is the name you gave the account.
Could you send me that to [email protected]
