Doesn't start on Windows boot
yamlegin
Thu Nov 04, 2021 5:47 am
A very small issue, but my MW7, 7.12.54, doesn't start with Windows 10 despite having that option checked. I've checked and double checked that the option is saved, but it never boots.
As I say, it's no big deal, I'm just curious as to why it doesn't work. I've attached a screen grab of the settings.
Re: Doesn't start on Windows boot
Thu Nov 04, 2021 11:55 am
If you hit CTRL + SHIFT + ESC to open Task Manager >> click the Startup tab >> does MailWasher show in the list, if so check that it's enabled, if not right click on the entry and Enable.
Failing that, try going into MailWasher change the setting to not start on startup >> Save >> change back >> Save.
yamlegin
Thu Nov 04, 2021 8:43 pm
Thanks, that works. Why didn't I think it could be that?
