Any ideas on how I can solve this problem?
I am getting lots of junk mail from domains like this. [email protected]. I used the filter as I read in your blog to delete them (*.sample.com), and it works like you said it would.
However, now they are getting tricky, like abc.wuie.sample.com. They are even using abc.wuie.sample.com. I hope I am making sense in describing my problem. Any ideas? I don't have any idea where to place the "*"
Re: where to place the "*"
That should matter, as *.sample.com would still match abc.wuie.sample.com
Is this a Custom Filter or a Blacklist wildcard entry you are using for the *.sample.com ?
