just downloaded mailwasher pro 30 day trial, installed it then tried to down load emails,it said trial has expired,
that was a quick 30 days,
Re: just downloaded mailwasher pro
Have you previously installed MW Pro on the machine ?
In either case, I've attached a trial reset registry patch, if you run this and answer Yes to import into the windows registry, restart MailWasher. Will hopefully do the trick.
- trial_reset.zip
- (304 Bytes) Downloaded 582 times
