hi
i have mwpro 7.12.54 (lifetime) and have discovered an update is available... HOWEVER...
...on clicking through i am at a stage where it says
"click install to begin the installation"
will this be a new installation where i have to redo all my email address info.... or will it update underneath my existing email info (so i just benefit from the updated parts.
cheers
updating... will i have to redo my email addresses as new.. ie again
- inq
Re: updating... will i have to redo my email addresses as new.. ie again
Hi there
It will update existing info.
If for some reason you do a manual uninstall, you get prompted if you want to keep your data files, which you want to do.
But that doesn't happen during one of these updates, only the uninstall.
