Hi there,
Version 7.12.67 Pro on windows 10 latest
I have used Mailwasher since 2006 and never had a problem until last year when I had a machine failure and had to restore from my daily backup.
The issue I have had ever since is an annoying one but surmountable each time.
It is:-
When washing emails, the ticked to delete emails delete accordingly and Mailwasher kickstarts Outlook 19 and Outlook 19 downloads remaining good emails. However when I review the Mailwasher Inbox the good emails are still in the Mailwasher inbox and I have to manually delete them. (tick and wash them).
Clearly something is wrong but I have no idea what.
Appreciate any help in solving this.
Mailwasher Pro does not delete washed good emails from Mailwasher inbox
- themrburns
- F1boatman
Re: Mailwasher Pro does not delete washed good emails from Mailwasher inbox
Hi there,
Mine is doing the same, not picking up emails on the sever before being shown on Outlook and also missing lots.
- F1boatman
I have just seen that this was not checked
- MailwasherPro.jpg (34.73 KiB) Viewed 3684 times
- Digerati
- Retired Microsoft MVP
Perhaps before, you had POP3 or you changed the default with IMAP and told it to delete the emails once deleted by a device
Bill (AFE7Ret)
Freedom is NOT Free!
I certainly am not an expert here, but one of the advantages (disadvantage?) of IMAP is that it allows you to access your email from different devices. For example, from your PC at work, your smartphone, and you computer at home. And if you delete it at work, the email stays on the server where you can view it again from home. With POP3, if you delete it at work, it is gone unless you change the default to keep it.themrburns wrote:when I review the Mailwasher Inbox the good emails are still in the Mailwasher inbox and I have to manually delete them.
What? That is not the same thing at all! Please read the OPs issue again, then start your own thread with your problem. Note your problem typically happens when Outlook is set to check mail automatically. It should be manually only when using MW.F1boatman wrote:Mine is doing the same, not picking up emails on the sever before being shown on Outlook and also missing lots.
