Google Search Console empty previews - MW v 7.12.67
user987654
Tue Mar 08, 2022 10:16 pm
This has been going on for a while but Google Search Console emails are all empty in the listview/browse list - you can't see the sender data, the preview does show text so you can see that it is legit - as there is no email address visible you can't whitelist it
Google Search Console Team <[email protected]>
Subject:
Your February Search performance for [websitename]
Header:
Authentication-Results: spf=pass
smtp.mailfrom=scoutcamp.bounces.google.com; dkim=pass
header.d=google.com; dmarc=pass header.from=google.com
Re: Google Search Console empty previews - MW v 7.12.67
Tue Mar 08, 2022 11:59 pm
Can you try setting a custom subject for these emails ?
https://support.google.com/webmasters/a ... 0528?hl=en
I seem to recall there was a problem with the way they were structured, and setting a custom subject might override that.
user987654
Wed Mar 09, 2022 12:13 am
I had a look but I don't see how I can change it as there is nothing to edit/change, I can tick some boxes and then "filter" by that doesn't provide any results :(
Guess I'll have to live with it.
Wed Mar 09, 2022 12:30 am
Can I get a sample message. If you view the message in MailWasher, click Show Email Info top left >> click Source tab >> if you copy/paste the entire text into a text file and email me that to [email protected]
user987654
Wed Mar 09, 2022 12:47 am
Done, subject of email: Google Search Console Team sample email - empty preview MW v 7.12.67, attached zip file of saved EML.
