MW pro not deleting email - only 10 at a time
wraiththe
Tue Jun 14, 2022 4:10 am
MW Pro is no longer deleting all my junk mail emails... I check the email for deletion and it will only delete 10 mails when I click wash mail. 54 slated for deletion will only remove 10. Then 44 left.... then a wash deletes 10 more to have 34 left and so on.
Removed and reinstalled... same thing... What gives?
Are you aware that you may not be aware?
Re: MW pro not deleting email - only 10 at a time
Tue Jun 14, 2022 11:19 am
If you go into Settings >> Accounts >> Incoming >> Advanced >> uncheck the two options to use PIPELINING >> Save.
That should fix this issue you describe,
wraiththe
Tue Jun 14, 2022 7:34 pm
HI, No such settings in advanced. I did however change the folder that MWpro moves deleted files to and that seems to have fixed it for now. I think the folder that they were sent to was deleted. Probably caused an error and is some kind of new bug I found.
