Change the display
garfld
Change the display
Fri Jul 01, 2022 1:39 am
I installed MW on a new computer. It is dividing the emails between today and yesterday. I want them all to be displayed in the 'From' category in alphabetical order, not split like this, and I can't find where to do it. A screenshot is attached. Thank you.
Re: Change the display
Fri Jul 01, 2022 10:58 am
If you right click over the Received column heading, uncheck the option Group By Received. That will remove that sorting by date for you.
garfld
Fri Jul 01, 2022 11:33 am
Perfect, so easy! Thank you!
