Mail for windows not a choice with Windows 11
- systifel
I upgraded to Windows 11 from Windows 10. Mailwasher pro showed Mail for Windows as a choice for mail program in windows 10, but not in Windows 11. I can't use my Mailwasher pro. Anybody else have the same problem?
Re: Mail for windows not a choice with Windows 11
I've attached a Registry patch that should sort this out. In the ZIP file, run the .REG and answer Yes to import into the Registry >> restart MailWasher and Mail For WIndows should appear in the list.
- mailforwin10.zip
- (644 Bytes) Downloaded 312 times
