Comcast won't work for me with mailwasher.
ronniejimmy
Fri Aug 26, 2022 6:43 pm
I have tried to get mailwasher to work and it keeps saying error "Failed to log into IMAP server.
I used the article on mailwasher and comcast mail setup, and it refuses to cooperate.
I manually log into my Comcast mail in web browser.
Re: Comcast won't work for me with mailwasher.
Fri Aug 26, 2022 9:24 pm
It should be
Username : Your full email address
Password : Same you use for your web browser logon
Server Address : imap.comcast.net
Under Advanced : The SSL option should be checked, this will also set the port to 993
Echo
Sat Feb 25, 2023 3:43 pm
That's exactly how I have set mine up - Port 993, IMAP, SSL/TSL, email address, password... it does not work. That's what the Comcast site says to do, too. But it doesn't work.
Mailwasher Comcast.jpg (36.01 KiB) Viewed 3465 times
Sat Feb 25, 2023 8:35 pm
Yes, usually that means that you are using the wrong password, please try logging in here:
https://connect.xfinity.com/appsuite/
Using the same logon details you are trying to use in MWpro and see if that works?
If it does, check your comcast mail or settings for a message about it blocking access to a program possibly?
If still no, possibly this page will help...?
https://answers.microsoft.com/en-us/mso ... e3c692a3b5
