Move spam to specific E-Mail-Folder?
bogus
Fri Sep 02, 2022 3:13 am
I use Mailwasher in connection with eM Client.
Mails that are automatically or manually identified as spam in Mailwasher, I would like to move it to a dedicated folder in eM Client.
Is that possible and if so how? Unfortunately, I can't find any setting for this.
Thanks for helping :help
ataraxy
Re: Move spam to specific E-Mail-Folder?
Mon Sep 05, 2022 9:18 pm
If you are using IMAP to access the email, you can set MailWasher to move deleted emails to a folder.
In the MailWasher setting for the account, on the Incoming tab, in the Advanced section, set the Move deleted messages into folder setting:
MailWasher - 2022_0905 - Move deleted messages into folder.jpg (48.02 KiB) Viewed 1959 times
Windows 10
bogus
Mon Sep 05, 2022 9:25 pm
