disc1 cab file not found
ThosRM2
Wed Dec 28, 2022 4:46 am
MailWasher Pro v7.12.97 is installed and working since initial installation.
Periodically, an update message pops up to install MailWasher Free 7.12.97. According to my list of installed apps, MailWasher Free is not installed, although it was previously.
What is the proper course of action here?
Thanks.
Re: disc1 cab file not found
Wed Dec 28, 2022 5:37 am
You could try navigating to the following directory . . . to delete the contents of the updates folder:—
Code: Select all
C:\ProgramData\Firetrust\updates
