Email was not completely downloaded
FishMan001
Fri Feb 17, 2023 12:20 am
I have started to get this as a header on the bottom screen, above the email display:
This email was not completely downloaded according to the performance settings. A full download will be possible after the completion of the mail check.
I have tried (I think), all of the possible combinations of the tick boxes in Settings > Performance, but I still get it.
Is there a way to make it go away and work again ?
Thanks,
Paul
Re: Email was not completely downloaded
Fri Feb 17, 2023 6:03 am
Hi Paul,
Yes, increase the "spam throttle" to maximum under Settings>>General>>Checking Mail, save changes and restart MWPro, this wont get rid of it 100%, but most emails should stop showing it.
This notification was added to fix another issue we were having, we hope to get rid of it in a future update.... cheers!
SzaboWasher
Wed Mar 22, 2023 7:48 am
I have the same issue. When will this be fixed?
SzaboWasher
Wed Mar 22, 2023 7:49 am
Moving throttle didnt work
Wed Mar 22, 2023 7:56 am
Yes, it's not really a issue as such, just an annoying message we need to remove... :) looks like we won't get to it until MWPro 8 though sorry, as we want to get this out ASAP....
If too annoying, you are welcome to uninstall, click YES when asked to save your user settings, restart, then install the previous version from here:
http://cdn.firetrust.com/downloads/mail ... _12_67.exe
