Version 2.75 released
MailWasher Enterprise specific news.
Wed Apr 07, 2010 7:52 pm
7 April 2010
* System check/diagnostic screen.
* Setup Wizard.
* Reverse Lookup option speeds up Grey listing (Default OFF).
* Stats and graphs included.
* 64 bit Unix version.
* Allow for no host name on SMTP helo/ehlo command.
* Improve connect/disconnect times.
* Check RBL response correct fixes DNS lookup failing.
* Also many back end and framework tweaks preparing the way for future changes.
Uprading is as simple as installing the file over your current version. Please take a backup first as you will not be able to downgrade.
Return to “News”
