Problem- Stuck
rajat_cloud
Problem- Stuck
Thu Mar 02, 2023 10:29 pm
I am using HideAway for the past 6 months I didn't have any issues but now its stuck at checking for license
Do anyone know how to rectify that?
g6radio
Re: Problem- Stuck
Fri Mar 03, 2023 2:11 am
Try entering your license key again and re activating.
I think this has worked for others in the past.
Re: Problem- Stuck
Fri Mar 03, 2023 6:45 am
Yes, that often works, but if it fails, send your key to support and they'll be able to check it to see if any current issues with that particular key....
