reply button fails
jimmww
reply button fails
Thu Mar 30, 2023 1:47 am
but only on one friend's emails, and only in Mailwasher. Once downloaded to thunderbird, the reply is ok.
And not all the time, only half the time. Is there anything in the mail that might cause MW to inactivate the reply and forward buttons?
Source:
My friend's emails are frequently not to be replied to on Mailwasher - the reply button does nothing - but once downloaded to thunderbird can be replied to.
Return-Path: xxxl.com
Delivered-To:
X-FDA: 80619557928.10.B08DC58
Received: from mail-yb1-f181.google.com (mail-yb1-f181.google.com [209.85.219.181])
by imf07.b.hostedemail.com (Postfix) with ESMTP id 8BE8AA0005
for <>; Tue, 28 Mar 2023 21:13:22 +0000 (UTC)
Authentication-Results: imf07.b.hostedemail.com;
dkim=pass header.d=gmail.com header.s=20210112 header.b=FWc1tMH6;
dmarc=pass (policy=none) header.from=gmail.com;
spf=pass (imf07.b.hostedemail.com: domain of xxx designates 209.85.219.181 as permitted sender) smtp.mailfrom=xxx.com
ARC-Message-Signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=hostedemail.com;
s=arc-20220608; t=1680038002;
h=from:from:sender:reply-to:subject:subject:date:date:
message-id:message-id:to:to:cc:mime-version:mime-version:
content-type:content-type:
content-transfer-encoding:content-transfer-encoding:
in-reply-to:in-reply-to:references:references:dkim-signature;
bh=DAXLQ5/t50LdkaiYxJATFwJ1Yb/0elIg5Z7mqR/GKmI=;
b=MWWmYR5i/2xEXFdK2GKbjs8k4rTbMNyVcwpbO4JWsfn8Gd2aFuNthqqQXHIAE3rBWj/59x
qTy4Aur+ikmbhmmGf8VDAgo8Qh76CSTX7Gf9eBJFw8WZNpC2aKiu4QTTqrl6euX02DRuni
nibzeV66fsadD7ov+yVPLmyFOKDwyMI=
ARC-Authentication-Results: i=1;
spf=pass (imf07.b.hostedemail.com: domain of xxxx.com designates 209.85.219.181 as permitted sender) smtp.mailfrom=xxx.com
ARC-Seal: i=1; s=arc-20220608; d=hostedemail.com; t=1680038002; a=rsa-sha256;
cv=none;
b=m10HuVwsh19+RE0pZCTAmGpSjnFvnpifsrJJ2UhmBssg7qAbqrfwIMA3gM8tJFAghHDiwN
MWaPH5Hrw7F9O/72X64rvEQxKgynCeMHkvvi8/1F3Fa5sfQIBwhgR+j2rQxA8e4VlgA8gP
rc5GnhQm0kcM0Rb1XYLrQktTSwzQvP0=
Received: by mail-yb1-f181.google.com with SMTP id z83so16916695ybb.2
for <>; Tue, 28 Mar 2023 14:13:22 -0700 (PDT)
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed;
d=gmail.com; s=20210112; t=1680038001;
h=content-transfer-encoding:to:subject:message-id:date:from
:in-reply-to:references:mime-version:from:to:cc:subject:date
:message-id:reply-to;
b=FWc1tMH6WWwUmAZR1ANNQGfMELQHTjmo1+TQU3uPwilRl7bPgc6tH+USN3ynDyShzY
HsSXVA41prC0Z+aGFWYt/MToCQ7q4ZgsBXNT9sjcxXEDoXnqMJowHI+nyLRKwHX57aPJ
3HAAfjKfJw2TOVYog5+hX879ZOA42bubcrOEUwvUztCnYWoAymXVQHDt/0UhPjgXXDgS
8o/mAjyoL+3svUiCzvE5DkV3AKheqLxvvVdf+z+tK6/GyVJ/nfMEQ7EmA9M/JHgbNaJ3
vjv0GcMX59HxUPBCRIfxvrbRO05YBw7ApMe7+63sqNt+jYNGNyStMwGto6ZuJ3H8rCHZ
carQ==
X-Google-DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed;
d=1e100.net; s=20210112; t=1680038001;
:in-reply-to:references:mime-version:x-gm-message-state:from:to:cc
:subject:date:message-id:reply-to;
b=gi68IjqWg9slgIZ0TBYZumQgiHgw3vIOUBDX+TBndsb7ApkLX3+vOk5LCzM9hhuDUd
M3n3uTttRVykpeX+omvxiXQv7IIcU7oxk5vuYCs2jG4cQCC2L6Nrs98C1aHBni+8k40R
sxz6sIWixU9peDovogkNVBJFEnxwBuAMFkpF+ixcDbv3NetMmT0O2yJNBOcoGL7O+g/a
GGzyRswTF6eggJJ29d5xsCKNv/Q0hAtj42buwE30Su9gKnguwP2YL+kOwcb5lH4AjS3d
fXsofaMmf+NmE3mtLlPITh8afkLiMHYc4OqOSco/b1hCQOf4H1vZoiNzyKKmW2S3WJtx
yhJQ==
X-Gm-Message-State: AAQBX9ftME4x93mEwgkHcKJLj5gDTVDqePQzz78FcH/zxMEL7OJokmj3
irgWaLyWAv30Yueh9VXQeRih+wAzRezh32h4An1xHLXh2co=
X-Google-Smtp-Source: AKy350ZarZfLH0J/e9Kc0mUOnQ5zTi1iooXPqfLd8LV1v/YxqYzucT/njaqS9MBwCGbrgPmiMlO/e+hQnWCZjSEyWV8=
X-Received: by 2002:a05:6902:18d5:b0:b75:3fd4:1b31 with SMTP id
ck21-20020a05690218d500b00b753fd41b31mr11434014ybb.1.1680038001241; Tue, 28
Mar 2023 14:13:21 -0700 (PDT)
MIME-Version: 1.0
References: <71d0a25b8789e4dbd75854a27.28e4997b63.20230328162152.e1475ea0db.1b59f4c8@mail139.suw241.rsgsv.net>
<CAPQKvLNH0VFR1kr6DpYmYrQNE2rcOqmzHEM2mAZ6fZN++1izBg@mail.gmail.com>
In-Reply-To: <CAPQKvLNH0VFR1kr6DpYmYrQNE2rcOqmzHEM2mAZ6fZN++1izBg@mail.gmail.com>
Anything there that might be interfering? Hmm. Where does that date icon come from? It's not visible in MW's display of source.
jimmww
Re: reply button fails - version 7.12.125
Thu Mar 30, 2023 1:50 am
Thu Mar 30, 2023 3:12 am
It's getting rendering by the HTML engine of the Board software — BTW, you might want to edit your original post . . . to delete some personal details (or else, you risk opening your friend to spam.) ;)
Thu Mar 30, 2023 4:07 am
Source:
Does the Reply button in MailWasher fail . . . if Thunderbird is already open & running before you click the Reply button in MailWasher? :think
jimmww
Thu Mar 30, 2023 8:37 am
"Does the Reply button in MailWasher fail . . . if Thunderbird is already open & running " Yes it does.
jimmww
Thu Mar 30, 2023 8:42 am
Thank you.
Could that have anything to do with the failure of the reply button?
Thu Mar 30, 2023 9:37 am
Can you describe . . . in detail, what really happens when the Reply button fails, for you.
Let's say you click the Reply button — can you describe what next you see on your display screen . . . if possible, a screenshot would help vastly.
Thank you.
Not at all — the Board software at these forums cannot possibly influence any MailWasher behavior on your computer. :)
jimmww
Thu Mar 30, 2023 2:18 pm
Nothing happens. The button blinks and ... nothing. Again and again. Same with the forward button.
It doesn't like something in the email source. But what? And is it fixable?
Thank you.
Ah, thanks.
Thu Mar 30, 2023 7:26 pm
Okay . . . let's try to re-map your MailWasher's communication with your e-mail client, Thunderbird.
(Can you navigate to) Settings >> General >> Washing Mail >> Use other application >> Browse (manually to where your thunderbird.exe resides . . . as per the following path corresponding to its architecture — 32-bit or 64-bit) >> (select thunderbird.exe, then) Open >> Save.
The 64-bit version of Thunderbird resides at the following default path:—
Code: Select all
"C:\Program Files\Mozilla Thunderbird\thunderbird.exe"
The 32-bit version of Thunderbird (when installed on a 64-bit OS,) resides at the following default path:—
Code: Select all
"C:\Program Files (x86)\Mozilla Thunderbird\thunderbird.exe"
ps:—
It's most important that under the Use other application drop-down menu, you do not fall into the temptation of selecting Thunderbird (in any form) — but instead, use the Browse button through Windows Explorer . . . to re-map the path of your Thunderbird. :!:
irvsp
Fri Mar 31, 2023 12:55 am
Have you checked the LOG file for that account?
HELP > USER FILES > LOGS then the logs for the date it happened on, then check these logs and look at the time it happened, usually would be at the bottom, all are TEXT files:
MWPapi.log
MWPapp_account name.log where "account.name" is the account where the problem happens.
If MWP had an error, it would show there.
jimmww
Sat Apr 01, 2023 6:05 am
Thank you!
That set me straight, I think. I'll let you know if it doesn't. I suspect the problem was I had the "Launch after washing mail" checked and I was replying before washing the list.
Duh?
But it only starting happening recently!
Jim
jimmww
Sat Apr 01, 2023 6:09 am
Nope that didn't do it.
and the Launch after washing mail only applies to bringing Tbird to the front after the wash, doesn't govern reply.
Maybe after a restart?
Jim
Thank you!
Duh?
Jim
jimmww
Sat Apr 01, 2023 7:21 am
All from the same sender, same day. Haven't tried re-installing MW or Tbird.
OK: smtp106.iad3a.emailsrvr.com [173.203.187.106]
also OK smtp89.iad3a.emailsrvr.com [173.203.187.89]
Not OK smtp71.iad3a.emailsrvr.com [173.203.187.71]
THIS DOES NOT ADMIT REPLY
X-FDA: 80629596936.27.28BFCC6
Received: from smtp71.iad3a.emailsrvr.com (smtp71.iad3a.emailsrvr.com [173.203.187.71])
by imf30.b.hostedemail.com (Postfix) with ESMTP id D3B8E180205
for <[email protected]>; Fri, 31 Mar 2023 15:34:50 +0000 (UTC)
Authentication-Results: imf30.b.hostedemail.com;
dkim=none;
dmarc=none;
spf=pass (imf30.b.hostedemail.com: domain of [email protected] designates 173.203.187.71 as permitted sender) smtp.mailfrom=[email protected]
s=arc-20220608; t=1680276891;
message-id:message-id:to:cc:mime-version:mime-version:
content-transfer-encoding:content-transfer-encoding:in-reply-to:
references:references; bh=YG7kOQmvW4rZRJ+srxwJApWIdIAL4zv91/T3rM4RuOM=;
b=EQH6z7cDhxHT4T+sb39M4/cxOZeGq4vgrtaLLZ5/A6DbVJtdUIjXENx+gQaiTCFZUrXZhE
f0v9nI8N+K4QGv3EDNZYHAsYiAvOxkUj5G6q4qgbX4SE9yIJQ+NvNmWzqJdUxpGzBNu9Gl
A3Ax/rEdqAXXbIDE5ZtqRhXeiWSFUxk=
dkim=none;
dmarc=none;
ARC-Seal: i=1; s=arc-20220608; d=hostedemail.com; t=1680276891; a=rsa-sha256;
cv=none;
b=k+DOaXJrw7BXT+X0BCSahCF6HW8HkYZ2VLNiELJiWdYcAI31zyMrX0GyxoNAQh57r3R5Va
xooVtheUdGWrY52ev/132+jU/52JUJMy/x8s1AEDiXSL3DvbdywZLpFNl5kXIBov0IwZGx
2zzIHMnFl8poFhvHQ1ziySWYyhHpLhg=
X-Auth-ID: [email protected]
Received: by smtp17.relay.iad3a.emailsrvr.com (Authenticated sender: xxx-AT-equitygroup.com) with ESMTPSA id 4CEA022361;
Fri, 31 Mar 2023 11:34:49 -0400 (EDT)
BUT THIS WORKS
X-FDA: 80629735494.23.B0BEB45
Received: from smtp89.iad3a.emailsrvr.com (smtp89.iad3a.emailsrvr.com [173.203.187.89])
by imf21.b.hostedemail.com (Postfix) with ESMTP id 0C5F21800D8
for <[email protected]>; Fri, 31 Mar 2023 16:31:47 +0000 (UTC)
Authentication-Results: imf21.b.hostedemail.com;
dkim=none;
spf=pass (imf21.b.hostedemail.com: domain of [email protected] designates 173.203.187.89 as permitted sender) smtp.mailfrom=[email protected];
dmarc=none
s=arc-20220608; t=1680280312;
references:references; bh=quN2ogVNaTCKP3fcfvxFF/RiroHjrUPRGUoR82mfydA=;
b=odSj5ULtKgyqkuD2PkINeYY9dMuDoY5tQ4gRyfdF4Z90j9pCD1Q/IL3C/X/IyCKa7pOGhD
l9btPn5VSN17m4qw3h6394+TU5cSjRUjnAN337sIDR70SToWI6wGFqqID0lxVVVPzYiZn/
WceZv0wXibJlawnbvhwKfWZ7NdnBPnI=
ARC-Seal: i=1; s=arc-20220608; d=hostedemail.com; t=1680280312; a=rsa-sha256;
cv=none;
b=eN9kd4nad/OUwJqIXnoK5yu2oN7FpiexHtx0lwVjVcJ1W+c9IJo309UU7EcYMI/431hSnp
MKebI4z1q0hiIgDh6R63af9S6OtM6KdIIL4w5xpuh5NvJMgOSAnklGNe7rxNXzYrIEJ30a
HQYGmFTlLpfeWxVdIxxG+Z/d+UCcazM=
dkim=none;
dmarc=none
Received: by smtp20.relay.iad3a.emailsrvr.com (Authenticated sender: xxx-AT-equitygroup.com) with ESMTPSA id 5BDA124975;
Fri, 31 Mar 2023 12:31:20 -0400 (EDT)
AND THIS WORKS TOO
Received: from smtp106.iad3a.emailsrvr.com (smtp106.iad3a.emailsrvr.com [173.203.187.106])
by imf18.b.hostedemail.com (Postfix) with ESMTP id BA5B2120038
for <[email protected]>; Fri, 31 Mar 2023 15:54:28 +0000 (UTC)
Authentication-Results: imf18.b.hostedemail.com;
dkim=none;
dmarc=none;
spf=pass (imf18.b.hostedemail.com: domain of [email protected] designates 173.203.187.106 as permitted sender) smtp.mailfrom=[email protected]
s=arc-20220608; t=1680278069;
references:references; bh=wDPiBvmXGbyaCwoccEbuqKAAJ7KD9Lk06cyUji+PJiA=;
b=uOMp+xL1TZ8pl+XIJI7QEPLB5gt7NyTW30uw5ozRU2bEDHtpiv5x18e0bO0WY5GVE/QqVu
ZaiaihijQzQf9MOXJdZX5QGO+Hiwx36gc5buGwzkTLCz3q2mBojZu6ua0HyLTcxqTROffv
bxbiaKK7GWD9gDPs82+y0sepWnTuLug=
dkim=none;
dmarc=none;
ARC-Seal: i=1; s=arc-20220608; d=hostedemail.com; t=1680278069; a=rsa-sha256;
cv=none;
b=E0kUlHgfYH1W0nltqtgUVtXCcKKQhW8u8w1Lqck34nnNQlMRF6hrieDVm5MehW+E2lneKD
MoLQFKTtr+T9FPNThGSIu5wF2cMngLXgLD7ts0kXuypVIHBy0/oAg1Kejg6sAIASoq7XLF
sCJ2/+0hGWnK0eBY0cnBjCYodmODr14=
Received: by smtp38.relay.iad3a.emailsrvr.com (Authenticated sender: xxx-AT-equitygroup.com) with ESMTPSA id AAF922905;
Fri, 31 Mar 2023 11:54:20 -0400 (EDT)
jimmww
Sat Apr 01, 2023 7:35 am
In MWPapp_jimw_hevanet_com.log
search is neg for repl or error
Nothing sig at the bottom, to my eye.
Jim
MWPapi.log
jimmww
Re: reply button fails and another problem
Mon Apr 03, 2023 6:28 am
Failure? to delete.
Mails previously deleted by MW come back - but only a certain segment -
in this case those from 3-1-23 to 3-23-23. So my total mail will jump from 230 to 720 on a check mail.
That's happened three times, so the re-deletes are not working.
And if in error I download mail to Tbird, I find dupes in every folder for those messages.
Should I ask hevanet if something is preventing MW from deleting some or certain mails?
I doubt he'll have an answer.
Is there a setting in MW that permits this that I should change? Or at the provider?
Jim
