Mailwasher not starting.
Pancake
Fri May 05, 2023 4:20 pm
My mailwasher is not starting when I start the computer. In the settings, I set it, To Launch When Windows Starts, but it keeps defaulting back to, None.
Re: Mailwasher not starting.
Fri May 05, 2023 4:40 pm
Can you please re-enable it, then click File>>Exit to close Mailwasher Pro.
Restart it and see if it holds this time....?
If not, try adding a shortcut to Mailwasher, (drag and drop from your desktop using the right mouse button) to your startup folder under either:
Start>>All Programs>>Startup folder.
OR:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp
Pancake
Sat May 06, 2023 2:18 pm
No. It is still set at None.
Sat May 06, 2023 4:51 pm
Did you try editing the startup setting directly into your GeneralSettings.xml file?
  1. (Navigate to) >> Help >> User Files...
  2. Backup your GeneralSettings.xml to a secure location
  3. (In the Window that Explorer throws open, right-click the) GeneralSettings.xml >> Edit with Notepad (or any other Notepad replacement program of your choice)
  4. Using copy-paste, add the following line (as highlighted in red on my illustration) — under the appropriate code <Application> (on my system . . . it appears on line # 15.)
    Code: Select all
    <NoStartupOption />
Pancake
Sat May 06, 2023 4:57 pm
OK. I will give that a go.
Pancake
Sat May 06, 2023 5:07 pm
Okay. That file is already there.
Sat May 06, 2023 5:13 pm
Did you mean the line?
Pancake
Sat May 06, 2023 5:15 pm
Yes it is there.
</Updates>
<Application>
<NoStartupOption />
<MinimiseToTaskbar>False</MinimiseToTaskbar>
<MinimiseOnClose>True</MinimiseOnClose
Sat May 06, 2023 5:23 pm
Hmmm . . . really strange — can you extract the MailWasher shortcut (from the file attached) . . . into the following directory and check whether it resolves your startup issue:—
Code: Select all
C:\Users\<YourUserName>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MailWasherPro.rar
(1.21 KiB) Downloaded 411 times
Pancake
Sat May 06, 2023 5:38 pm
Yes, I have done that but I can't restart the computer yet to try it. I'll get back to you as soon as I have done that.
Pancake
Sat May 06, 2023 9:05 pm
No. Still not working.
Sat May 06, 2023 9:31 pm
Does the MailWasher setting now, continue to remain at None . . . or, Launch when Windows starts up?
If the setting continues to remain at None . . . your security system (or some program) might be blocking/deleting your MailWasher startup entry — did you make any change/s (or install any new program) just around the time this issue started?
If the setting is now displayed as Launch when Windows starts up . . . MailWasher could be starting-up with Windows but probably just hiding behind the System Tray Notification Area?
Sun May 07, 2023 6:56 am
Yes.... the usual other reason it wont load on startup is that MWPro is set to run as admin from either the shortcut in the startup folder, or the programs .exe file itself...
Locate and right click on these, click Properties, and ensure that nothing is ticked under the Compatibility tab.
If still no good, click Start, search for msconfig and click msconfig.exe.
Click the startup tab, and ensure that MWPro is ticked (if there).
Pancake
Sun May 07, 2023 3:13 pm
Ok. I will do as you suggested and try those.
Pancake
Sun May 07, 2023 3:43 pm
No. Still not working. I have done all you suggested. I set it to Run When Widows Starts, saved it then I looked in the Inbox then went back to settings and it had reset itself back to NONE. Weird. Maybe I should uninstall it and install it again.
I did not make any change/s (or install any new program) just around the time this issue started.
