Cannot Install Latest Version
Jancux
Mon May 08, 2023 10:04 pm
Good morning to you all!
I am attempting to install the latest version of Mailwasher on a replacement laptop running a fully updated Windows 10 64 Bit system.
The installation package requests that I install Network Framework 4.8.
When I attempt to install this I am informed that it is incompatible with the operating system.
Please advise how I should proceed.
C
Re: Cannot Install Latest Version
Mon May 08, 2023 11:08 pm
The latest version of .NET Framework is the 4.8.1.
The minimum version of Windows 10 with which .NET Framework 4.8.1 is compatible is the 1903 (19H1) — you can find the version of your Windows by running the following command:—
Code: Select all
WinVer
The latest stable (64-bit) .NET Framework 4.8.1 (as of typing this post) is KB5022729 — it was last updated on the 29th of March 2023.
Tue May 09, 2023 6:21 am
Yes, .net should be installed by default anyway, try running windows update and see if it can update from there....?
Thu May 11, 2023 8:38 am
Some breaking news . . .
Microsoft To Deliver .NET Framework Via Windows Update, Catalog, On Older Windows 11 And 10 Verified Source:—
https://www.neowin.net/news/microsoft-t ... 11-and-10/
