I am a long-time Mailwasher Pro (Lifetime) user. My records show at least since 2010, but I am quite sure it was earlier. Last week GoDaddy changed their access and I can no longer access it using Mailwasher. My main email is that account. It is my understanding that Mailwasher does not support this MS Exchange-based email. Is there a fix coming soon, or do I have to abandon Mailwasher?
Hewie Poplock
[email protected]
GoDaddy email
- TrustFire
Re: GoDaddy email
ATM, we are testing a βeta which was released as a fix for the GoDaddy issue.
- hewiep
Re: GoDaddy email
Thanks for the response. Would you like me to be a beta tester?
Hewie Poplock
Hewie Poplock
Re: GoDaddy email
Hi Hewie, yes, most welcome.... have added you to the beta group, when you go here:
index.php
Once logged in you can scroll do the bottom and see the beta testing group now, latest MWPro version is the last message on the post, "Latest beta version of MailWasher Pro 7 - Mk2"
Please ensure you post anything you find in the beta forums though, not in the general public forums.
Cheers!
index.php
Cheers!
- TrustFire
Re: GoDaddy email
Welcome on board, Hewie.
- JohnBlase
Re: GoDaddy email
I have the same problem as Hewie. Last week, GoDaddy switched over to Oauth authentication, and Mailwasher no longer works for the account they are handling. If you need another Beta tester for this, I will also volunteer. I have Mailwasher running on both Win7 and Win10 machines, so I might add a little variety to your testing.
John Blase
John Blase
Re: GoDaddy email
Thanks John, have added you as well, just as I said above to Hewie, let us know how it all goes....
Cheers!
Cheers!
- TrustFire
Re: GoDaddy email
John, welcome to you as well.
