Unknown error
raymondv
Unknown error
Sat Jun 24, 2023 11:14 pm
Since this morning I have an "unknown error" on my outlook account. Any idea what is causing this?
My other pc's have this error too.
The Enforcer
Re: Unknown error
Sun Jun 25, 2023 1:45 am
I think I had the same issue. It might have been an outlook/hotmail issue, but it's resolved for me now by itself.
Cheers,
TE
Re: Unknown error
Sun Jun 25, 2023 7:47 am
Yes, socket errors are often firewall related, so check that first... if not resolved, I'd try deleting and re-setting up the account....
Open Mailwasher Pro and click, Settings>>Accounts, click your account and click, "Remove Account", click, "Yes, remove it", close and restart Mailwasher Pro.
On the next screen enter your email accounts password and click Save again.
(NOTE: you may be asked for permission to allow MW access to the account, if so, ensure you agree to this)
If it shows successful, click Save again on the outgoing tab then you are all set.
raymondv
Re: Unknown error
Sun Jun 25, 2023 4:40 pm
Problem solved itself.
A complete reinstall did not work. I already tried that.
