I need to know what the required OAUTH settings are for connecting to ATT / Yahoo POP3 Web Mail.
QUESTION............:
Can someone explain the exact settings needed for OAUTH ATT / Yahoo POP3 Web Mail?
NOTEs:
-- Mailwasher Pro (v. 7.12.125) stopped working with OAUTH ATT / Yahoo POP3 Web Mail in the last week for no apparent reason.
Thanks for your help,
Steve
Mailwasher Pro (v. 7.12.125) OAUTH settings for ATT / Yahoo POP3 Web Mail
- burley
Re: Mailwasher Pro (v. 7.12.125) OAUTH settings for ATT / Yahoo POP3 Web Mail
OK, I figured out how to make Mailwasher Pro start working again for my ATT / Yahoo POP3 Web Mail.
SOLUTION: Changed Password FROM "ATT Login Password" TO "Secure Mail Key" [generated in user's online ATT account]
NOTES:
(From the two dated notes below, one can see that the ATT/Yahoo Web Mail Software has "Flipped Flopped" between requiring "ATT Login Password" or "Secure Mail Key" as the password ).........:
- 2023-07-13 (TODAY) -- Mailwasher Pro starts working gain...
Solution was to change Password to.. "Secure Mail Key", instead of my "ATT Account Password"
- 2023-03-02 -- Mailwasher Pro starts working gain...
Solution was to change Password to.. "ATT Account Password", instead of my "Secure Mail Key" [generated
For Reference,
below are the settings I am using in MailWasher Pro TODAY for my now working ATT / Yahoo POP3 Web Mail .
Inbound......
Server Type POP3
Server Address: inbound.att.net
Username: xxxxxxxxxxxxxx
Password: "Secure Mail Key" [generated in user's online ATT account - NOT account Password]
ADVANCED Settings....
Server Port Number: 995
Security connection: OAUTH
"Check" box Use secure authentication
PIPELINING.....
"Check" box Enable for checking mail
"Check" box Enable for deleting mail
Outbound.....
SMTP server address smtp.mail.att.net
Server Port Number 465
"Check" box SMTP server requires authentication
"Check" circle User same settings as my incoming mail server
Secure connection: SSL
NOTES:
For Reference,
Inbound......
Server Type POP3
PIPELINING.....
Outbound.....
