I am researching some lost emails, and got to wondering if they had been filtered out by MailWasher and subsequently deleted. I searched Filters for the argument "team" (without quotes) and got a hit for a filter titled "Miscellaneous". However, for the life of me, I can find nowhere in that filter definition the string "team". (This filter contains a number of regexes that have accumulated over time, if that's of any significance.)
If the word "team" is in that filter someplace, would sure like to find it ... However, I see no way to get MW to show me where it thinks the word "team" occurs in the filter. Any suggestions?
Filter Search reports hit, but cannot find search term in the filter definition
Re: Filter Search reports hit, but cannot find search term in the filter definition
Yes, does sound a bit odd alright, all I can think to try is to delete that filter and re-create it possibly....?
(copy the regex you are using first)
If just the same, you may need to re-write the regex differently possibly?
