Check for Updates not working...
dlmsontag
Mon Nov 20, 2023 6:29 am
Either automatic or manual check for updates does not work at all. The only way I'm able to update my MailWasher Pro is to periodically check the changelog to see if there is a new version.
Settings > General > Updates has Automatic check for updates checked and is set for 2 days. To my recollection, I've left this setting to the default as installed.
If I select Help > Check for updates... absolutely nothing happens. I don't even get a notice telling me I'm up to date.
MailWasher Pro has full access through firewall.
Any ideas on how to get this working? Thanks!
Re: Check for Updates not working...
Mon Nov 20, 2023 6:31 am
Yep, here's how to fix this problem......
First, (with MWPro closed) if you go into C:\\ProgramData\\Firetrust\\updates\ and delete the files updates.aiu and updates.aiu.part (if present)
See then if the updates work via Help>>Check for Updates.
If no, possibly the update file is corrupted in your user files folder.... try copying updater.ini from help >> common files >> to help >> user files.
To do this......
- Open MWPro, click, Help>>Common Files
- Copy the "updater.ini" file to your desktop or another folder.
- Click, Help>>User Files,
- Minimise the folder that opens,
- Click File>>Exit to close MWPro,
- Maxamise that folder,
- Move the "updater.ini" file into that folder.
Restart MWpro and try updating again....
If still no good, possibly MW is not being allowed access to the updates folder for some reason.... please click, Settings>>General>>Updates and click Browse.
Select your C: Drive and create a new folder named MWinstall (or whatever name you like) and click OK.
Click Save and then try checking for updates again under Help>>Check for updates.
dlmsontag
Tue Nov 21, 2023 9:19 am
Thank you ... Did not start working until after I rebooted machine. Now I wait to see if it picks up the next update automatically or not.
Have a blessed day!
general714
Thu Dec 12, 2024 4:00 am
Hi - same problem. Tried all the suggestions, still not working. I didn't have updates.aiu at all. Any additional suggestions? Thanks.
Thu Dec 12, 2024 4:49 am
Yes, I'd recommend you just install the update manually from here:
If just the same, try those directions with the update installed....?
general714
Thu Dec 12, 2024 5:20 am
Thanks. Yes, updated manually and worked fine, but still doesn't show anything when I try to update from the application. I get an hourglass symbol next to the cursor for about 2 seconds, then nothing...! Oh well, agree I can check the site and update manually as needed.
Thu Dec 12, 2024 9:21 am
Yes, pretty odd none of those options worked to enable the update from within MWpro though...
One other possibility is that your firewall or AV program is blocking the updater.exe program MW uses to check for updates......?
general714
Thu Dec 12, 2024 9:28 am
Turned off VPN and Malwarebytes, no difference. From the Event Viewer:
Faulting application name: updater.exe, version: 2.1.0.0, time stamp: 0x4db7da1c
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x006fee48
Faulting process id: 0x7A80
Faulting application start time: 0x1DB4C0A979878E8
Faulting application path: C:\Users\xxx\AppData\Roaming\Firetrust\MailWasher\updater.exe
Faulting module path: unknown
Faulting package full name:
Faulting package-relative application ID:
A mystery...maybe try a Windows reset, keeping files/apps?
Thu Dec 12, 2024 1:00 pm
Yes, no reason it should be faulting alright..... try running MWPro as admin and see if that helps possibly?
If no, yes, you can try uninstalling/rebooting/reinstalling, but ensure you backup first...
Here's how to backup your MWPro settings:
Open MWPro, click File>>Export,
Click Browse to choose where to save the backup file,
Type a name for it (anything you like)
Click Save,
Then Export.
To restore in future, (IF required) click File>>Import, locate the file you saved and click Import.
general714
Thu Dec 12, 2024 1:03 pm
Thanks will try.
general714
Fri Dec 13, 2024 10:43 am
Hi - working! Thanks very much for your help. In the end it was what I thought, a Windows Repair Install did the trick. Didn't even have to reinstall MWP. Cheers!
Fri Dec 13, 2024 12:10 pm
Excellent, good to hear thanks!
