Problem installing Encrypt 1.X on windows XP
Troubleshooting and help for Encrypt
clauderenaud
Fri Nov 14, 2008 9:09 am
Hi all,
When I try to install Encrypt, I receive the following eror message "Windows Installer Loader
This setup requires the .NET Framework version 1.1.4322. Please install the .NET Framework and run this setup again. The .NET Framework can be
obtained from the web. Would you like to do this now?
Oui Non".
This version is no longer available apparently and as I currently have the DotNet 3.5 sp1 version installed I thought Encrypt would detect and use it, but unfortunately no.
So how to proceed to install Encrypt ?
Should I give up for now ?
Regards,
Claude Renaud
Pierre
Re: Problem installing Encrypt 1.X on windows XP
Fri Nov 14, 2008 10:43 am
Here is the link for the .net framework you need.
http://www.microsoft.com/downloads/deta ... laylang=en
clauderenaud
Fri Nov 14, 2008 11:10 am
Pierre wrote:Here is the link for the .net framework you need.
Ok, thanks, I will try it ASAP ...
Regards,
Claude Renaud
clauderenaud
Sat Nov 15, 2008 10:41 am
Pierre, I downloaded and installed the requested DotNet package, and then Encrypt and all ended well... thanks!
Regards,
Claude Renaud
Pierre
Sat Nov 15, 2008 1:20 pm
Claude, keep this link in mind as you may have to install other .net framework versions as well for other applications. Glad it fixed your problem. :)
