Red Box will not go away
DirectoryDude
Sat Jan 27, 2024 5:25 pm
Several times on different emails the Red Box will not change to green.
Screenshot 2024-01-26 232025.png (27.54 KiB) Viewed 2854 times
Mitch
3alienswebhosting dot com Out of this World Web Hosting
Re: Red Box will not go away
Sun Jan 28, 2024 7:01 am
If the account type is POP, try clicking, Settings>>Accounts, click your email account, click the Incoming tab, and uncheck, "Store cached emails" click Save.
If the account type is IMAP, click, Settings>>Accounts, click your email account, click the Incoming tab, and change the "Server Type" to POP, and uncheck, "Store cached emails" Click Save, then change back to IMAP.
Restart MWPro and let me know if that is any better.....?
DirectoryDude
Sun Jan 28, 2024 5:01 pm
That worked thanks
Why all of a sudden will it start doing that nothing changed in my settings.
Mitch
Mon Jan 29, 2024 6:57 am
yes, it's a bug in MWPro, should be resolved in the next update... :)
DirectoryDude
Thu Feb 22, 2024 8:36 am
And when will that be?
Mitch
Thu Feb 22, 2024 9:02 am
Not sure yet.. you are welcome to try the latest beta, however it still has some issues, I'll let you know when its more stable so you can give it a try.....
Tue Mar 19, 2024 8:55 am
OK, latest beta seems very stable, so if you wanted to give it a try, please email support at firetrust dot com and refer to this post and I'll send a link... cheers!
blueboy714
Fri Mar 22, 2024 12:03 am
When will that update be released? We've been waiting for months now for a fix for multiple issues.
Fri Mar 22, 2024 7:01 am
