is colour coding no longer available
Dalton
Wed Feb 28, 2024 1:22 am
Hi all,
I seem to remember that many years ago it was possible to apply colour coding to emails from different sources for easy identification, is that facility still available? I cannot seem to find anywhere to assign colours to the different emails.
Thanks in advance for any help provided.
Re: is colour coding no longer available
Wed Feb 28, 2024 6:14 am
Yes, you can sort of do this with your filters, it colours the filter name when caught with whatever colour you choose, eg:
Digerati
Retired Microsoft MVP
Wed Feb 28, 2024 7:40 am
You can create a filter for each of your contacts, or group of contacts then assign a color to that filer. Since there are limited choices of colors in Mailwasher, you can edit the Filters.xml file (with Notepad) and insert a hex value of a different color - giving you nearly limitless color options. Just make sure you make a copy of the Filters.xml file for safe keeping, just in case you goof while editing.
Image Bill (AFE7Ret)
Freedom is NOT Free!
Dalton
Wed Feb 28, 2024 10:52 pm
Thank you for your help, that's sorted it :-)
