Filters
David Haley
Filters
Thu May 09, 2024 1:57 am
My apologies, I'm sure this question has been covered somewhere but, I was unable to find it. When setting up a filter can you add more than one word to a line? Such as (example), as, the, Jim, Bob, cops? OR, can only one word be in one line? Should I use "AND", "OR", etc. between words?
Thanks...Dave
Re: Filters
Thu May 09, 2024 8:01 am
Hi Dave,
Yes, that is no problem, if the filter is a plain text filter, MWPro catches the exact wording of whatever you write in there, so you'd need one word/phrase per filter rule.
However, if you want MWpro to catch a bunch of words, instead of plain text, select regex from the last box:
Then you can place a pipe, eg: | between each word so MWPro will search for each word by itself, eg:
Regex filtering is pretty specialized but works really well once you get your head around it..... this page is pretty good from these forums:
http://forum.firetrust.com/viewtopic.ph ... a757b8635b
Cheers!
ruthlessgrapnel
Re: Filters
Wed Jun 26, 2024 2:40 pm
When setting up a filter, you can add multiple words to a single line. You can list the words to filter separated by commas or spaces on the same line. For example:
When you add these words to the filter, the model will try to avoid using or make suggestions related to those words in its answers.
