Connecting to Fastmail via IMAP
John1947
Tue Jul 13, 2010 2:09 am
I have WIN-XP/SP3 and have been using MailwasherPro5.something for many years, connecting with Thunderbird with never a problem. I have started tidying up my various email sources and now they all forward to Fastmaill from where I propose to download to the email client in Opera. I tried to use old Mailwasher to preview Fastmail and cull the garbage but couldn't get it to connect either with IMAP or POP - error was username or password fail.
I downloaded MailwasherPro2010 trial last night expecting that might give me a better result. That fails for apparently the same reasons. In all cases I have entered and re-entered usernames and passwords (paying attention to all Fastmail instructions I can find) but can't get any preview connection. Using the same username/password combo I have no problem connecting with Fastmail directly, outside Mailwasher.
Can anyone suggest a fix?
Re: Connecting to Fastmail via IMAP
Tue Jul 13, 2010 2:12 am
If your password has any special characters, like $ or #, then that will be the cause for MW2010 not working.
Otherwise it should work...here's my settings which are working for me
anniebrion
Tue Jul 13, 2010 2:14 am
There is a small bug in 2010 were a password with special characters might cause a mail fetch to fail.
Try changing your password but only use letters & numbers, see if that fixes the problem.
*Edit* RD beat me too it :oops:
Tue Jul 13, 2010 2:23 am
anniebrion wrote:*Edit* RD beat me too it :oops:
It's another late night watching bad movies :)
Another possibility is that the Fastmail account is locked. John1947, if in MailWasher2010, go Help >> User Files >> Logs >> open todays date folder >> look for MWPapp_<accountname>.log where <accountname> is the name you gave the account, in there you might see more information why it's not logging in. Feel free to email me the details to [email protected] or post here if you can't tell what's going on.
John1947
Tue Jul 13, 2010 7:42 pm
Hello again Rusticdog & Chris Gleason.
Thanks for suggestions so far. Nothing you've suggested has met with success.
Here's the latest MWP10 log entry which shows a change in the failure activity recorded.
(I checked my login log at Fastmail but it said there that the reason for the failure was "unavailable").
07-13-2010 16:53:19.125 Info MWPfetch::ObjectThreadMethod acc=Acct-114596801 AccountType=1 user=<removed>@fastmail.fm host=mail.messagingengine.com port=993 logintype=1 sslmode=1
07-13-2010 16:53:19.125 Info MWPapplication::FetchAccount acc=Acct-114596801 AccountType=1 user=<removed>@fastmail.fm host=mail.messagingengine.com port=993 logintype=1 sslmode=1
07-13-2010 16:53:19.125 Info IMAPservice::IMAPservice host=mail.messagingengine.com port=993
07-13-2010 16:53:19.140 Info LOGIN acc=Acct-114596801 user=<removed>@fastmail.fm host=mail.messagingengine.com port=993 logintype=1 sslmode=1
07-13-2010 16:53:23.671 Info C: LOGIN *******
07-13-2010 16:53:24.640 Info S: mw2 NO The account or service you are trying to access is unavailable or disabled. Please login to the web interface for more details
07-13-2010 16:53:24.640 Error IMAPservice::Login SocketException - GetLine failed() failed with code 0: The operation completed successfully. IMAP Login host = mail.messagingengine.com port = 993 user = <removed>@fastmail.fm LoginType = 1 SSLmode = 1
Tue Jul 13, 2010 7:46 pm
Now that's a new one.
So once you logon to Fastmail website, go Options >> Account Preferences >> right down the very bottom is IMAP/POP logins disabled ?
John1947
Tue Jul 13, 2010 8:15 pm
:thumbsup :D :lol:
Well spotted Rusticdog.
I unchecked the appropriate box (can't say whether I was responsible for checking it in the first place -- probably was!).
Now MWP10 connects and downloads from Fastmail.
Many thanks for the detective work and thanks to all others who contributed to the help effort. I'm impressed by the level of support.
'Bye for now.
John1947 (where did the "Rattled Rabbit" apellation come from??)
Tue Jul 13, 2010 8:37 pm
John1947 wrote::thumbsup :D :lol:
'Bye for now.
Fantastic, glad it's sorted.
John1947 wrote:John1947 (where did the "Rattled Rabbit" apellation come from??)
That comes from your post count in the forums, we created a NZ flavour to the forum ranks....it progresses something like....
One Post Wonder
Guardian Gecko
Parent Penguin
Wise Weta
MrBill
Prudent Pukeko
Wed Jul 14, 2010 5:39 am
One Post Wonder
Guardian Gecko
Parent Penguin
Wise Weta
And apparently you can customize individuals as you choose, from time to time...
Bill Walton
Wed Jul 14, 2010 6:04 am
One Post Wonder
Guardian Gecko
Parent Penguin
Wise Weta
Yeah, I imagine being the "Big Dog on the Block" does have some perks associated with it. :roll: :devil
Wed Jul 14, 2010 8:09 am
In the past whining about your level name has resulted in getting it changed for some folks. That can be good "Not a Sheep" or not so good "Major PITA" depending on the beer level in NZ. :-)
