Automatic Minimize
- cfheinz
- Guardian Gecko
Automatic Minimize
My older versions would automatically minimize when I went to my email client (Agent). 2010 doesn't appear to do this and I'm unable to find a setting to automatically minimize.
Carl Heinz
- anniebrion
Re: Automatic Minimize
This is what you want.
- Capture.PNG (87.43 KiB) Viewed 8120 times
- cfheinz
- Guardian Gecko
Thanks. Found it shortly after I posted. There is a bit of a learning curve, isn't there?
Carl Heinz
- QuietOne
That's true but the new MWP2010 is far more flexible AND far more accurate in it's Spam checking (albeit a little slower for now as well), but all in all I think you'll like it if you give it a chance. There's still loads of features that are yet to be added but as soon as things slowdown some the programmers are gonna get back at it and you should see updates being posted every so often as new features (some of the missing stuff) get's added in and bugs get fixed. Right now they're working on some crash bugs that didn't show up in Beta.
- Sidewinder
- Weary Womble
I think the one your looking for is here:cfheinz wrote:Thanks. Found it shortly after I posted. There is a bit of a learning curve, isn't there?
It is a bit confusing to have the two minimize options split onto different screens but where they are makes sense once you think about it.
The Minimize MW when mail program launched should trigger the minimize when you click the Launch E-Mail program button while the Minimize MW after Wash should shrink it after you press the Wash Mail button and the wash process has finished.
