Serial Reset Please
emrlabs
Serial Reset Please
Tue Jun 25, 2024 10:38 am
Hello, this is James Golik, a longtime registered user. I have several serials on my account. I just switched to a new Surface Pro 11. Please reset my serials as I no longer have those installs.
Thank you .
James
Re: Serial Reset Please
Tue Jun 25, 2024 12:23 pm
Hi James,
Yes, I can do, however your 2 current lifetime keys don't actually need resetting...?
They are the keys:
YZ######-##6M
HN##-####-##55
Blanked out the middle parts to prevent others using them.
If still problems, please email support at firetrust dot com and we can go from there....
rigidwestern
Tue Jun 25, 2024 7:13 pm
I am also using Surface Pro 11 and coincidentally found out about the problem you shared.
