"Update your sign-in technology" from Microsoft
atiamplan
Sat Jun 29, 2024 8:56 am
I've been using MailWasher to check my Outlook emails for spam and to bounce them, which has so far worked wonderfully! However I've recently received the below email from Microsoft:
Update your sign-in technology before September 16th, 2024 to maintain email access.
The safety and security of your information is top priority for Microsoft. To help keep your account secure, Microsoft will no longer support the use of third-party email and calendar apps which ask you to sign in with only your Microsoft Account username and password. To keep you safe you will need to use a mail or calendar app which supports Microsoft’s modern authentication methods. If you do not act, your third-party email apps will no longer be able to access your Outlook.com, Hotmail or Live.com email address on September 16th.
What do you need to do?
If you are receiving this email, you are currently using an email or calendar app that uses a less secure authentication method to connect to your Outlook.com email account. You will need to upgrade your third-party mail and calendar app to a version which supports modern authentication methods.
Microsoft provides free versions of Outlook for your PC, Mac, iOS, and Android devices which can be easily downloaded and connect to your email account. Using an updated version of an Outlook application will ensure you are connecting in the most secure way.
How can you set up your Gmail, Apple Mail, or other third-party mail application?
Various non-Microsoft applications will have their own steps for connecting to your Outlook.com email account using modern authentication methods. See our help article - Modern Authentication Methods now needed to continue syncing Outlook Email in non-Microsoft email apps. However, you may need to contact the creators of those applications to provide you with instructions. In many cases, simply removing and re-adding your account with the latest version of that application will configure it to use modern authentication methods.
So will MailWasher need an update to access any Outlook.com accounts? Or do I need to do something differently? Either way, the email itself isn't awfully clear about what I need to do next.
Re: "Update your sign-in technology" from Microsoft
Sat Jun 29, 2024 9:45 am
Yes, looks to me like that just means you cannot logon via just your email address/password.
MWpro uses https://www.microsoft.com/en-us/securit ... t-is-oauth for logging in via your account settings within MWpro, so should still work fine as long as setup to use this option as per below screenshot....
DorthyLindgren
Thu Nov 28, 2024 10:56 pm
If you do not use your email or password to log in, how can you get in? Do you have to use MWpro to access it?Geometry Dash Scratch
Last edited by DorthyLindgren on Fri Nov 29, 2024 2:46 pm, edited 1 time in total.
Fri Nov 29, 2024 6:10 am
Sorry, yes, you still use your email/password, but not via plain text, it needs to be entered via the Sign in with Microsoft button....
