Version 7.15.5 - Display setting won't stick.
MichaelD
Sun Jun 30, 2024 1:12 am
Updated to 7.15.5 a few days ago.
I always uncheck the "Enable custom window border" setting, since installing the update the setting does not stick, yes I do save the setting.
When I reboot the PC the next day the setting has re-enabled itself to use the custom border.
This also happens on my two laptops with the update installed.
Regards
Michael
Mailwasher 7.15.5.JPG (19.35 KiB) Viewed 2567 times
Re: Version 7.15.5 - Display setting won't stick.
Sun Jun 30, 2024 7:49 am
Yes, fixed in the latest beta, hope to have it released soon, or if you would like to try it now, please email support at firetrust dot com and refer to this post....cheers!
