Automatic download of washed mail
markaz
Fri Jul 16, 2010 12:57 am
Just upgraded to Pro 2010 and everything operates the same with one exception. In the old version after I selected the mail to be washed it launched the default email client and the unwashed (mail I wanted) mail was automatically downloaded. In Pro 2010 after the mail is washed it launches the client but I have to manually "Get Mail". I checked the settings but couldn't find where Thunderbird is to automatically download the mail I want. Help?
Thanks in advance.
Desperate people do desperate things.
Re: Automatic download of washed mail
Fri Jul 16, 2010 1:01 am
In ThunderBird you go Tools >> Account Settings >> Server Settings >> you'll see this here for each account. Though just remember it'll download if you open ThunderBird by mistake, before using MailWasher.....something I do all the time.
anniebrion
Fri Jul 16, 2010 1:03 am
rusticdog wrote:In ThunderBird you go Tools >> Account Settings >> Server Settings >> you'll see this here for each account. Though just remember it'll download if you open ThunderBird by mistake, before using MailWasher.....something I do all the time.
You could use the "Go Thunderbird" beta exe :facepalm It's working well here :devil
Fri Jul 16, 2010 1:12 am
Just to clarify for markaz, beta testers are working on an app that when MailWasher launches the email client it will trigger a download. I personally would like to integrate it more into MailWasher first and cater to other email programs :)
Fri Jul 16, 2010 3:13 am
For ALL concerned, I'd like to see more integration as well. :thumbsup :mrgreen:
markaz
Fri Jul 16, 2010 4:10 am
Thanks to all for the replies.
I just don't get it. rustic - That setting was already checked at the time of the upgrade. That's what is surprising to me. After marking any emails for deletion and then clicking "Wash Mail", Thunderbird would launch and automatically download the mail I wanted. Now it doesn't after the upgrade.
Fri Jul 16, 2010 4:20 am
markaz wrote:Thanks to all for the replies.
If all of your msgs are marked for deletion then TB will not be called.
Here are the Settings that control the process:
MWP Load APP.png (51.54 KiB) Viewed 13177 times
markaz
Fri Jul 16, 2010 5:10 am
The attachment MWP Load APP.png is no longer available
Sidewinder - I don't think you read my message carefully. I said "After marking any emails for deletion and then clicking "Wash Mail", Thunderbird would launch and automatically download the mail I wanted." So I wash what I don't want and keep what I want downloaded. It's what I keep that won't downloaded automatically when TBird is launched. Here's my settings.
Fri Jul 16, 2010 5:26 am
You have the old MailWasher still installed ? What does that have set....I'm confused myself why this would happen.
Fri Jul 16, 2010 6:02 am
Sometimes you can run into command line arguments that confuse things, check what you have in v6 and duplicate it in 2010
http://kb.mozillazine.org/Command_line_ ... derbird%29
Fri Jul 16, 2010 9:34 am
[quote="markaz"]Sidewinder - I don't think you read my message carefully. I said "After marking any emails for deletion and then clicking "Wash Mail", Thunderbird would launch and automatically download the mail I wanted." So I wash what I don't want and keep what I want downloaded. It's what I keep that won't downloaded automatically when TBird is launched. Here's my settings.
Clarify please, does TB open or maximize from the tray but doesn't download?
Or does nothing happen.
What does MWP status show?
What OS are you using.
markaz
Sat Jul 17, 2010 2:58 am
Issue resolved......and I don't know why. Just passing this along for informational purposes and wanted to say Thanks for everybody's efforts in attempting to resolve this.
I sent test emails from 4 different email accounts to the default account in MWP. I noticed that two of the email address were previously added to the "Friends List" and two were not. I did not mark any for deletion and washed all four emails. Thunderbird launched and the two emails that were marked as a Friend downloaded automatically. The other two did not even though they were OK.
I uninstalled MWP2010 and reinstalled it. Made sure the settings were the same as MWP6.5.3. I resent the four emails as before and washed them. This time TBird launched and downloaded all four messages.
Why it would only download known email addresses marked as a friend, I have absolutely no idea and why it works properly now, I don't know......and don't care. :scratch
Sat Jul 17, 2010 3:12 am
Can't say I understand how that made any difference, but if its' working now then I'm not sure I want to :)
