Problem with re install
timhoff
Fri Nov 21, 2008 5:35 pm
GOT IT THANKS!
Re: Problem with re install
Fri Nov 21, 2008 6:30 pm
I think the setting for the e-mail program to use is on the tools menu, option selection. If the list doesn't work look to the right a bit and you'll see a "Specify" button to manually add one in.
timhoff
Sat Nov 22, 2008 4:07 am
Under tools there I check options go to Options and there is nowhere to specify anything there is nothing there regarding the default email program anywhere. I have looked everywhere and there isn't a place to set the mail program. I also uninstalled and re-installed the software and the same thing happens, I am dumbfounded.
Pierre
Sat Nov 22, 2008 12:44 pm
Have a look at this screen shot.
MW Specify.jpg (78.43 KiB) Viewed 9286 times
Just enter your information there.
Ikeb
Microsoft MVP with a slice of PITA
Sun Nov 23, 2008 8:11 pm
Proving once again that a(n edited) picture is worth a thousand words! :thumbsup
Mon Nov 24, 2008 4:36 pm
Putting that picture into a sticky post would be a very good thing, how many times has this come up?
