How Do I add BOUNCE & BLACKLIST to MAILWASHER 2010.
angelah
Fri Jul 16, 2010 2:44 pm
I've heard it before, don't Bounce messages. I have some PERSONAL (not bulk) stalkers I want to continue to BOUNCE.
Please advise.
Thank you.
Re: How Do I add BOUNCE & BLACKLIST to MAILWASHER 2010.
Fri Jul 16, 2010 3:13 pm
So then click the "mark for bounce" option and bounce them, is that not working for you?
Upper right corner of the message preview pane.
angelah
Fri Jul 16, 2010 3:31 pm
Sorry, my post was not clear at all. I used to be able to ADD "Bounce" and "Blacklist" to the Mailwasher bar from the Tools menu. I want my checkmark back vs. having to right click and Bounce Each one. I think I may have to stay with the old version. If I could ONLY get it to open.
Fri Jul 16, 2010 3:41 pm
There's no way at present to add those columns. You can also select multiple messages, then right click, select the action in the menu
angelah
Sat Jul 17, 2010 9:53 am
Thanks for the reply. That would be a welcomed feature, which at the moment, I miss.
