Hello,
can I exit the programme with a parameter?
Mailwasher close
- steve1
Re: Mailwasher close
Sorry my bad english,
How can I exit Mailwasher? Is it possible over a command line?
I would like before I exit Windows, mailwasher close.
- anniebrion
You could use the windows taskkill command to kill the MailWasherPro.exe & MailWasherProApp.exe tasks, but this is not as tidy/safe as using exit from MWP's menu
You could write a script using AutoIT to close MWP via its taskbar menu. I might have a go at this as I would like to exit MWP via a schedule
Is there a reason in particular you would like MailWasher to exit before Windows ?
No problems at all.steve1 wrote:Sorry my bad english,
- steve1
Thanks, i test AutoIt!
I exit Windows with the 12Ghost Tool "Shutdown". Mailwasher show a error at a restart of Windows.
Thinks Mailwasher is not exited correctly.
OK great. We just fixed the problem you describe in MailWasher 1.0.4.
So if you go Help >> Check for Updates >> install the new version and you won't get these crash reports anymore.
- anniebrion
The attached AutoIT application will close MWP, but if you start MWP again without rebooting or before shutting the PC down then you will be prompted to send an error log, you should just click the ignore button if this happens. I've not yet found a way to close without the error
The application just checks to see if either the MailWasherPro.exe and/or MailWasherProApp.exe processes are running, if they are it ends them. You might need to run this under admin.
- Close MWP.zip
- (385.92 KiB) Downloaded 642 times
- steve1
- jack90125
- anniebrion
Anyhow, the OP was having a problem due to a small logic problem in the earlier version that is fixed now in the latest
So they will not need to close MWP manually prior to shutdown
Not always possible if you are doing stuff in a script.jack90125 wrote:why not just right click on the tray icon and exit? KISS
- Sidewinder
- Weary Womble
See PM from me.anniebrion wrote:Not always possible if you are doing stuff in a script.jack90125 wrote:why not just right click on the tray icon and exit? KISS
Anyhow, the OP was having a problem due to a small logic problem in the earlier version that is fixed now in the latestSo they will not need to close MWP manually prior to shutdown
- anniebrion
This version opens MWP and chooses Exit from the file menu
No error log screen as MWP closes normally
- Close MWP V2.4.zip
- (279.26 KiB) Downloaded 656 times
- steve1
hello anniebrion,
i have installed version 1.04.
Close MWP V2 opens MWP but the programme, however, is not closed.
- anniebrion
What version of windows are you using?
I's working fine under Windows7x86-64HP & Windows XPx86Home
Strangesteve1 wrote:hello anniebrion,
