Third-party email apps
hans peter
Sat Jul 20, 2024 1:42 am
Does this apply to Mailwasher?
Protecting your information is a top priority for Microsoft. To protect your account, Microsoft will no longer support the use of third-party email and calendar apps where you sign in using only your Microsoft account username and password. Using an email or calendar app that supports Microsoft's modern authentication methods provides better protection. If you don't fix this, as of September 16, 2024, your third-party email apps will no longer be able to access your Outlook.com, Hotmail, or Live.com email address.
/hans peter
MW Pro 7.15.10
Win11
Re: Third-party email apps
Sat Jul 20, 2024 7:45 am
Yes, that is nothing to be concerned about (re MWPro anyway), as it supports Microsoft’s modern authentication methods (OAUTH) so will work fine.
Details here:
https://support.microsoft.com/en-us/off ... 986499a90d
Although unlikely unless you had mail issues, you can check in MWPro to ensure it is using OAUTH under the Incoming tab>>Advanced, click the button under "This server requires a secure connection (SSL)" for any Microsoft based accounts, (also as per below screenshot) if not, you are currently using an app password and need to enable OAUTH and use the normal password for that email account....
Merel
Tue Jan 07, 2025 11:26 pm
I tried to choose OAUTH in the context menu but that option does not appear.
I still see only incoming messages of my @telenet.be account.
Messages of hotmail accounts are not shown in the main window
I need a more detailed procedure (step by step)
Wed Jan 08, 2025 9:16 am
Yes, if no OAUTH option you must be using a old version...
Latest is here: https://www.firetrust.com/products/mail ... o/download
barkerxavierr
Thu Jan 16, 2025 8:22 pm
I downloaded the new version and had this problem too!
