Is sticking with Mailwasher Pro 7.12.125 a safe choice?
immanueljohnston
Mon Sep 09, 2024 6:52 pm
I've been using Mailwasher Pro 7.12.125 without difficulty. I attempted to upgrade to 7.12.173, but encountered issues with OAUTH and my 16-digit security code (using POP3 for AT&T and Yahoo accounts such as [email address removed]).
There is a newer version (7.12.193) available, but my primary worry is security. Are earlier versions, such as mine, still considered safe, or are newer versions more secure (excluding OAUTH)?
Re: Is sticking with Mailwasher Pro 7.12.125 a safe choice?
Mon Sep 09, 2024 9:03 pm
Yes I'd advise you update to 7.15.10 from here:
It works fine with OAUTH which is more secure, so no more need of a app password....
