Microsoft Web Outlook Oauth not working
Klark
Mon Sep 16, 2024 6:19 am
Hi everyone.
I hope I'm posting my question in the correct forum section. As some of you are aware, Microsoft will require oauth login as of 9/16/2024. I did search the forums and read the related questions/comments regarding the oauth issues but I still can't figure it out.
I downloaded the MailWasher trial version a few days ago, added my Hotmail/Outlook credentials with TLS/SSL and it is working but randomly. I'm trying to switch to oauth but after I click on MS Outlook logo in the settings of MW, the popup screen is blank and I find the instructions on that screen really vague. Please see the attached image.
I'm not sure what I need to do to grant access to MailWasher.
Re: Microsoft Web Outlook Oauth not working
Mon Sep 16, 2024 8:35 am
Yes, usually that means you don't have the edge webviewer2 app installed on your PC, so MW tries to send you a webpage to sign into manually....
I'd try installing the webviewer app, restart your PC and see if that works? first, ensure you have MWPro 7.15.10 from here: https://www.firetrust.com/products/mail ... o/download
If you did not, try again now? if still no, or you already had this, install webviewer from here: https://go.microsoft.com/fwlink/p/?LinkId=2124703
Restart your PC afterwards then try again....?
See this post for how to setup if unsure:
viewtopic.php?f=50&t=64995#p176783
Klark
Tue Sep 17, 2024 9:58 am
Wow, thank you so much Gingbat. I would've never guessed it was the evil Edge webviewer. Ever since Microsoft unleashed it, they use it to display useless ads in every app, so I clobbered and uninstalled Edge and the viewer completely. I just installed the lastest Edge and was able to create the Oauth creds. Everything is working. Thanks agains.
Thu Sep 19, 2024 6:09 am
Yes, really not sure if the webviewer app itself is the problem, or it's just the portal everything else uses to display their ads.... (possibly like blaming computers for spam)? :)
Good to hear that worked out all the same though!
