Is it possible to utilize a single account on several machines at once?
irischamplin
Wed Nov 06, 2024 9:52 pm
Hello
I would like to know MailWasher Pro 7's licensing conditions. I want to know specifically if a single license may be used on several machines at once using the same user account.
I intend to utilize the software on both my laptop and desktop computer. Would you kindly explain the limitations on licensing?
I appreciate your help and time.
Re: Is it possible to utilize a single account on several machines at once?
Thu Nov 07, 2024 5:46 am
Yes, you can use your MWPro 7 registration key on up to 3 computers for your own, or your families use in the same household.
Here's how to transfer/copy to your new computer also.....
First, install MWPro 7 to your new PC from here:
http://www.firetrust.com/en/products/ma ... o/download
Then, to transfer/copy your old data, (OPTIONAL) on the old PC's MWPro installation click File>>Export, and save the exported file somewhere you can locate it to move it to your new PC.
Note you can also click Help>>Registration on the old MWPro installation and get your registration key from there if required.
Then, within MWPro on the new PC click File>>Import and import this file.
