Mailwasher wont fully minimize to tray
nancypeery
Mon Nov 11, 2024 5:44 pm
Hello,
I've been using Mailwasher Pro for years to manage my email, and its actually been running fine with windows blinds up until yesterday. After a reboot Mailwasher suddenly will no longer fully minimizes to the system tray while using any windowsblinds skins. It still minimizes to the tray, but also reapears on the taskbar a second after its minimized. (Minimizing to tray is a mailwasher function, not the WB option). If I change to a non-WB Visual Style, all works fine.
Any suggestions?
Re: Mailwasher wont fully minimize to tray
Tue Nov 12, 2024 5:50 am
Yes, can you please try this first.
Ensure MWpro is closed.
Go to Start, type run (then click the Run file so it runs) then in the ‘Open:’ box type (or copy / paste):
%AppData%\Firetrust\MailWasher
Delete the Startup.xml file and restart Mailwasher....?
