Version 5
Andrew Cool
Version 5
Fri Nov 22, 2024 3:03 pm
Version 5 was "almost ready" according to an update comment posted in April 2020.
4 and 1/2 years later, is there any hope of v5 (and Rules) ever being released? :dead :frown
Re: Version 5
Fri Nov 22, 2024 3:16 pm
Aiming for end of next week - actually!
Re: Version 5
Sat Nov 30, 2024 7:25 am
Didn't get it finished, developer was sick on Thur and Fri. Almost there though
Re: Version 5
Tue Dec 24, 2024 9:03 pm
It's here, restart to get the latest. A few things missing, but we're doing them when back from holiday.
In HideAway, click the Custom Rules button and you'll be taken to the screen with 3 sample rules, which you can delete/replace.
The rules run in order of precedence from top to bottom, so rules at the top take precedence over rules under them. DOMAIN rules take precendence over PROCESS, PORT and CIDR
DOMAIN = any website domain or subdomain. eg netlfix.com or docs.google.com
PROCESS = any application on your PC. eg chrome.exe or notepad.exe
PORT = any port on your PC. eg Port 8080.
CIDR = any IP address in CIDR notation, and must be /32 notation. eg 192.168.1.19/32 to target just that IP. To easily calcuate a CIDR for an IP address or IP address range, visit https://www.ipaddressguide.com/cidr
Note: Some local ports and IP addresses are already ignored by HideAway so as not to interfere with printers etc
Note: These rules are a work in progress, next we'll be adding ALL (your entire computer) and then you can run individual rules above that. Then the ability to Ignore and block, edit and change order of a rule.
Usage: Click the Plus (+) icon to add a rule, and the trash icon to delete a rule.
When you switch between Custom Rules and Preset Rules, HideAway will switch the connection to what ever Rule(s) is displayed on the screen.
Re: Version 5
Fri Jul 18, 2025 11:29 am
There's been some more updates. And this help file should show you how it all works.
https://firetrust.com/products/hideaway ... stom-rules
Andrew Roberts
Re: Version 5
Mon Jul 21, 2025 2:06 pm
https://firetrust.com/products/hideaway ... tom-rules/ wave road
Appreciate the update. Hopefully this time it leads to a proper release — it’s been a long wait since 2020
Re: Version 5
Mon Jul 21, 2025 2:36 pm
Yes, we're getting to this new UI
BBQs
Re: Version 5
Tue Jul 22, 2025 10:04 pm
Will get the new UI if I downlead it today plz?? :D
Re: Version 5
Tue Jul 22, 2025 10:07 pm
We're working on it, but it's not ready yet. So the version you download today will eventually update to the new UI
BBQs
Re: Version 5
Tue Jul 22, 2025 10:08 pm
Ok thank you
BBQs
Re: Version 5
Sat Jul 26, 2025 12:06 pm
BTW: Now I can resize the GUI to a suitable size I am as happy as Larry (assuming Larry was a happy man) Thanks for still a great VPN - Paul
Re: Version 5
Sat Jul 26, 2025 7:07 pm
Thanks! Just grab any corner until the mouse changes to a double headed arrow, then press and hold the left mouse button to resize it to something which suits.
