Run two instances of MW7 ?
dougm
Mon Dec 02, 2024 10:29 am
Hello,
I understand there's no way to run with different configuration files for different email addresses.
So, as a work around, is it possible to start two instances of MW 7 with different install directories, or path for the config files? Each of these instances of the program would look after one email address?
Thx
Doug
Re: Run two instances of MW7 ?
Tue Dec 03, 2024 6:18 am
Hi Doug, Sorry but no, only one MWPro 7 installation can run at a time within windows.....
Only way to run 2 would be to run MWPro 7 AND MWpro 6 at the same time....
