Disable Hot Keys?
BDinger
Disable Hot Keys?
Sun Aug 01, 2010 1:05 am
Is there any way to disable the Hot Keys aspect of Mailwasher 2010? I think there may be a conflict with a macro program I use.
Thanks.
anniebrion
Re: Disable Hot Keys?
Sun Aug 01, 2010 1:15 am
Could you explain a bit more ? :?
Sun Aug 01, 2010 1:33 am
Think they just mean the main HotKey...
Under Settings, just delete the contents of the MailWasher HotKey field and press Save, that will force it to [none]
anniebrion
Sun Aug 01, 2010 1:35 am
Ah, that hotkey :) :facepalm
